Control an IPS 405 power supply via Labview
Dear all,
I need to configure an IPS 405 Power supply from Iso-tech and controll it via a LabVIEW code.
Can I use NI-VISA to control this power supply via RS-232?
I looked everywhere but couldn't find LabView drivers for this power supply.
May I ask you what to do? Any luck on how to build a custom Power Supply Labview driver? or does VISA can help control any Power supply? but will I still need to find driver for the power supply? what can i do if no drivers are available?
Thank you in advance for your help.
Serge
Message 1 of 8
(7,725 Views)
Probably there is no driver yet, but if you put the manual online maybe someone can help.
greetings from the Netherlands
Message 2 of 8
(7,723 Views)
There is an entire section on the Instrument Driver Network on creating your own driver.
Message 3 of 8
(7,721 Views)
Hello Albert,
Thanks for your quick reply.
The complete datasheet can be found at this address: http://za.rs-online.com/web/p/power-supplies/4461601/ too big to be attached on this forum.
I hope someone can help! I have read how make a custom driver but it's look quite tricky to actually make your own driver as i am not an expert in Labview....Hope somebody can assist.
The datasheet can also be found at this adresse http://uk.rs-online.com/web/p/power-supplies/4461601/
Message 4 of 8
(7,709 Views)
I got the manual and it is basic serail read and writ that almost do the trick.
There is also the hyperterminal you can try out.
At the moment I have to earn money but maybe I can write a very small example tonight to get you started for the IPS
Message 5 of 8
(7,706 Views)
Hello Albert,
I m not pushing, but just wanted to find out if anything cames up with regards to this post?
Thanks in advance for your kind help.
best regards,
Message 6 of 8
(7,684 Views)
Accepted by topic author Crg27
Hi
Thanks for remembering me.
This is in LV 2011 and I used an dc power template to start.
I only adapted Initialize.vi and Configure output.vi  and you should only test these.
I filled in the correct serial parameters.
place it in instr.lib
I really would like to see the status but it is not a verbose instrument.
Message 7 of 8
(7,678 Views)
Thank you very much Albert for your help!!
Message 8 of 8
(7,656 Views)
