Control cursors using ag6000 driver
Trying to figure out a way to control the cursors on the MSO6104A scope using the ag6000 IVI instrument driver.  I cannot find any commands that reference cursors or markers at all.  Is it possible to set horizontal and vertical cursors?
(3,359 Views)
You should be able to use ag6000_WriteInstrData() for sending a SCPI command string, which controls the cursors. You can look up that SCPI command string in the instruments programming manual.
(3,345 Views)
