Control of Xbee pro with X-stick in LabVIEW
I have successfully established communication and control of the I/O pins on my Xbee pro via the software from Digi called X-CTU. I am using an X-stick to wirelessly send the data. I am now trying to create a vi to do the same. I am having difficulties. I want to be able to set a certain pin hi or low on the Xbee(pin 21 for instance).  I have searched through the forums and I can’t seem to find what I am looking for. I have attached my unfinished vi for review. Thanks in advance.
(3,991 Views)
Update:
I used the basic read and write example from NI and got the communication to work.
(3,983 Views)
