Controlling AC Voltage Output via LabVIEW
I'm trying to control an AC voltage output from 0~250V using LabVIEW, but I couldn't find any device that does this kind of operation and can communicate with LabVIEW. All the NI DAQs available only operate at low voltages (-10/10V) for signal generation. Does anyone know any power supply or method that could do this function?
Thank you!
Kenny
(4,952 Views)
Thank you!
Kenny
This is not an NI question.   With the proper Purchase Order someone might lead you to a solution..... Google it first!
Spoiler
Spoiler
Smiley Wink
(4,947 Views)
Accepted by topic author kennycaldas
You really haven't used your Google-fu if you can't find a programmable AC supply. Keysight and California Instruments are just two of several vendors.
(4,940 Views)
