Controlling Agilent 33250a from Tektronix TDS5000B with RS-232
Hi all,
I am trying to control the input waveform using Agilent 33250a which is controlled by Tektronix TDS5000B with RS-232.
I've downloaded the LabVIEW drivers ag3xxx for the Agilent 33250A. However, if I run "Agilent 33XXX Series Generate Standard Waveform.vi", it gives an error: 1073807346.
Do I need any other driver or software to make this work?
Please give me any advice.
SJ
(3,921 Views)
Do you have the instrument configured in MAX and install VISA?
(3,907 Views)
Thank you for your help.
I tried to check with MAX, but it was not configured.
I am sure that VISA is installed because I checked RS-232 through TekVISA program.
Then, what should I do next?
Thanks in advance,
SJ
(3,903 Views)
Would you please have highlight execution turned on when you run the vi.  I'd like to know at what point you get the error.
What version of NI-VISA do you have?  Please go to Measurement and Automation (MAX), go to the software tab, and you can see NI-VISA followed by a version number.
Also, please look at the following link:
http://digital.ni.com/public.nsf/allkb/A2561CDE98B66DD4862566510078264F
Sammy Z.
(3,892 Views)
