Controlling Mainframe Module with PyVisa
I have a Stanford Research System SIM900 Mainframe and I can communicate with it using Pyvisa. Now, I would like to communicate with the PID module SIM960 connnected to it.
I can send commands such as : mainframe.ask("*IDN?"), etc...
My problem is that I cannot send command to the module.
For example to assign the module to the 4th mainframe port outside of python I would have to type : CONN 4,"PID"
and I could then type: PID*IDN?
to get the model of the module with the variable name PID.
In python I can only give one argument to mainframe and I cannot write something like : mainframe.write("CONN 4, "PID"") and mainframe.write("PID*IDN?")
To summarize, I want to send command from python to the PID module through the mainframe (COM5 for example)  but I don't know what's the syntax for it.
Does anyone ever experienced this situation?
Vincent
(5,797 Views)
Do you have anything related to NI hardware or software? I would suggest contacting Stanford Research or posting on a python forum.
(5,781 Views)
Vincent
You are not using NI instrument.
You are not using NI software.
You should be asking these questions somewhere else.
(5,773 Views)
