Controlling a TDS6000 ocilloscope via 10/100 ethernet using tekVISA and visual basic 6
How can I control a TDS6000 ocilloscope via 10/100 ethernet using tekVISA and visual basic 6.
Can you specify an example of a VB project that do the job?
thanks and regards
shauli
(3,346 Views)
Personally I don't have any examples, but other people in the forums might. If you haven't already, I would also try the Tektronics forums to see if they have any examples...
Logan S.
(3,331 Views)
