Controlling a spectrum analyzer connected to gpib/ethernet using linux
Hello all,
I want to communicate with a spectrum analyzer (HP8563E) connected to a national Instruments GPIB/Ethernet
device in Linux over the command line using C/Perl/Python. I am a complete newbie to command line instrument
control. I have used Labview and I can setup the Ethernet/GPIB as well as talk to the spectrum analyzer just fine.
I did come across some python programs that control spectrum analyzers that are connected directly to the
computer. What I would like to know is hot to setup so that I can talk to this remote device.
Any help with this is highly appreciated.
Thanks - Ram
(5,354 Views)
I was able to get a sample code which controls an ethernet/serial device and it was addressed by
the following:
ASRL::192.168.1.150::2::INSTR
I can communicate with it via
viOpen (defaultRM, ASRL::192.168.1.150::2::INSTR, VI_NULL, VI_NULL, &instr);
I have a GPIB at ethernet ip 192.168.1.140 with the spectrum analyzer at address 18.
I tried to open it with
viOpen (defaultRM, GPIB::192.168.1.140::18::INSTR, VI_NULL, VI_NULL, &instr);
but it cant seem to communicate with it.
I am new to this so any help is most appreciated.
I can communicate with the device using Labview and the Measurement and Automation
Explorer on a Windows machine.
Thanks again - Ram
(5,331 Views)
I believe your resource name may not be correct.
Instead of GPIB you should have TCPIP like in this article.
Let us know how this works.
Christian A
(5,294 Views)
Christian- Thanks for your help.
I was able to play around and read more. I was able to communicate with the Specrum Analyzer over GPIB. The way
to make it work was to set it up first using the 'gpibexplorer' as a GPIB0 interface. Once this was done everything
else was easier.
(5,262 Views)
