Could not load file or assembly 'NationalInstruments.NI4882, Version=8.6.20.412
I get this error message on a Vista x64 machine. I'm using VS2008. the same program is runing fine on XP x32. Any idia?
(3,814 Views)
NI 488.2 should work with VS 2008, you may have to reinstall the 488.2 drivers to ensure you are up to date you can find the latest drivers at ni.com/support.
Scott M.
Message Edited by Scott-M on 06-01-2009 04:57 PM
(3,781 Views)
Solved.
I changed the target proccessor to x86.
(3,776 Views)
