Cypress EZ-USB FX2 (68613)-EEPROM missing
Hi every body,
I have GPIB-USB-HS cale it was working well until i got message (Cypress EZ-USB FX2 (68613)-EEPROM missing) i couldn't see GPIB address, Could anyone help me to identify this error is it software or hardware error
Thanks in advance
Abdallah Farmalawi
(6,840 Views)
Hey there,
Would it be possible for you to translate the message in the pop-up into English? We'll be able to help you better that way. Are you having issues with the GPIB-USB-HS, or with a connector? If  you disconnect the Cypress EZ-USB, does the GPIB-USB-HS function normally? NI doesn't make the Cypress EZ-USB, so you may have better luck on that company's forums if you are having an issue with that hardware. This forum is aimed mostly at resolving issues with NI's hardware.
Thanks!
(6,815 Views)
Thank you so much for your reply and co-operation,
"The message means that the driver installed successfully",
I want to clarify that GPIB-USB-HS from NI made in Hungary,as shown in the picture below.
I think the problem with GPIB-USB-HS, because i al ready have checked the connector terminal, just when i connect the GPIB-USB-HS, to computer i got the above message, also the READY or ACTIVE doesn't blink.
Thank you again.
Abdallah Farmalawi
(6,805 Views)
This message could be seen for a GPIB-USB-HS if the internal memory which identifies it as a GPIB-USB-HS has been erased or physically damaged in some way. The GPIB-USB-HS will need to be repaired or replaced.
(6,789 Views)
