DCPWR IVI Drivers
Hi guys
I have installed an ivi-com driver for dcpower
the driver is SorensenDC
I m trying to run the driver using a logical name and ivi dcpower class driver
but its not running in mode simulate
and i dont have yet the instruments
anyone can probe in simulate mode and says me why its not running
thanks
(4,336 Views)
Hello Geodo,
       What model of Sorensen power supply are you using?  If there is an IVI-C Specific Driver available for it, you should use that over the IVI-COM driver since you are using the IVI-C Class Drivers (which is the same thing that I say in this post).  Some IVI drivers do not implement simulation, so you should check if simulation works when you call the IVI-COM Specific Driver directly without the Class Driver and COM Adapter.
Cheers,
NathanT
(4,320 Views)
Hello Nathan
I have probed this driver (is a sorensen driver for all model DCS, DLM models of sorensen) and it is a IVI-COM driver
I tried probe it with ivi-com driver directly (using a logical name but using the ivi-dcpwer class ivicom, not ivic or ivicomadapter), and its give me an error of access to memory
it search in 0000000000 address position.
Anothers ivicom drivers for other models are running in my applications without problems (only there are any functions that its not supported)
Can it be a problem for the specific driver?
(4,310 Views)
