DLL crashing when function called
hello,
why is the attached subvi crash everythime I try to run it? I'm calling a function from a dll and it crashes? I'm trying to communicate with an external device via serial port.
has anyone seen something like this before?
(4,223 Views)
You've provided neither the subVI, the dll, information on the dll (i.e. .h file, where it came from , etc.). See http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=3580. Is the subVI something you wrote? If not, where did it come from?
(4,214 Views)
I apologize for that.
Thanks for your speedy response. The dll is for a multichannel analyzer (Pocket MCA 8000a) developed by amptek.
the link for the dll information is in the following link
I hope you can help with this. I've unsuccessfully tried to gain help with this before.
(4,212 Views)
The subVI is still missing. Did you write it? There are a lot of ways that you can crash LabVIEW when using the Call Library Function Node. Incorrect calling convention, parameter mismatch, etc. If you post the subVI, I'll give it a look when I have time - probably not until tomorrow.
(4,205 Views)
I've attached it now. I belive if you double click on icon (subvi) in the first attachment it should open as well.
(4,202 Views)
It crashes on my pc as well though I don't have any hardware. The function call looks okay. I'm stumped. Maybe if you posted this question on the LabVIEW forum you would have better luck. There are people there a lot better than I am in using dll's.
p.s. clicking on the subVI in the first attachment would not work. Each VI (and subVI) is a separate file, correct? You can double click on the subVI because the main VI has the path to the subVI on your local system. If you post a main VI with subVIs in the future, do an application distribution and create an llb. This will include all the subVIs in a single file.
(4,182 Views)
Dennis, thanks for your help.
(4,175 Views)
