DPO7014 can’t determine saving CSV data range by programming command
When the scope recall length is 50K, I want to save scope channel 4 full data as csv file.
Trying the command as below:
data:stop 50000;
SAVe:WAVEform:FILEFormat SPREADSHEETCsv;
SAVe:WAVEform CH4, ,"C:\CH4";
But I always got 20K data length , not 50K that I set.
I have looked for the programming manual P.439.
In the manual, it could be use “DATa: STARt and DATa: STOP” command to determine what range I want to save.
But in real, it not so.
(3,859 Views)
That screenshot says there are only 20k samples.  So why should you expect more?
(3,840 Views)
