02-06-2018 09:18 PM
CALL Syntax
Description
| ibask (ud%, option%, value%) | Checks current configuration parameters |
| ibcac (ud%, v%) | Become Active Controller |
| ibclr (ud%) | Clear specified device |
| ibcmd (ud%, cmdbuf$) | Send commands from string |
| ibcmda (ud%, cmdbuf$) | Send commands asynchronously from string |
| ibconfig (ud%, option%, value%) | Set current configuration parameters |
| ibdev (BdIndx%, pad%, sad%, tmo%, eot%, eos%, ud%) | Open and initialize a device descriptor |
| ibdma (ud%,v%) | Enable/disable DMA |
| ibeos (ud%,v%) | Change/disable EOS mode |
| ibeot (ud%,v%) | Enable/disable END message |
| ibfind (udname$,ud%) | Open device and return unit descriptor |
| ibgts (ud%,v%) | Go from Active Controller to standby |
| ibist (ud%,v%) | Set/clear ist |
| iblines (ud%, clines%) | Returns status of the GPIB control lines |
02-09-2018 03:53 PM
02-12-2018 10:46 AM
Check the info provided by nyc, with this you can know what is the meaning of each sign and get an idea of how to use the functions of the DLL
