Defining a Logical Device in Windows XP
How do I define a Logical Device in Windows XP Professional?
I have a PCMCIA-GPIB+ card installed in my laptop computer.  I'm running the Measurement & Automation Explorer software (version 3.1.1.3004).   I can define the Interface Name just fine (ie. GPIB0)  I can even send very basic commands to the Logical Device/Instrument (a HP3457A Multimeter in this case), such as "BEEP" using the Measurement & Automation Explorer, Communicate with Instrument Window.  However, I'm unable to define the Logical Device/Instrument in Device  Manager so that other applications can see the device.   In the Device Manager page for the National Instruments PCMCIA GPIB+ Properties, there is no Device Templates Tab to define a Instrument.
Is there something I'm missing?
Dave
(4,063 Views)
There hasn't been anything to set in Device Manager for quite some time. VISA aliases can be set in MAX so that you can specify a VISA resource called "scope" for example. Or, you can simply use GPIB0::INSTR::n where n is the address of the instrument. If you're not using VISA (though I recomend you do), low level GPIB functions usually just require the address by itself.
What other applications do you require to see the instruments? Once you've done a scan for instruments in MAX, they should all be available.
(4,048 Views)
Thanks for your reply Dennis.
I'm not familar with VISA or MAX.  Nor am I a programmer.
A little on my background.  I'm an analog electrical engineer trying to get a simple TCL program running to measure some voltages on a analog circuit board I'm developing.  I've done this before years ago when my  PC was running Windows 98 or even DOS.  Once I had the logical device definded,  I used the "ibfind",  "ibwrite"  and "ibread"  commands to communicate with the instruments.  In the interactive session,  I can issue the command "ibfind GPIB0"  just fine.  However the command "ibfind GPIB0::INSTR::3"  returns an error message.
I'm not a programmer, and would like to avoid having to learn a new appliation such as VISA.
Dave
(4,035 Views)
Okay. I understand now. Your ibwrt and ibrd should work the same (i.e. ibwrt 3, "*IDN?", 5 for an instrument at address 3). You do not need to do an ibfind. Use ibdev instead. Ibdev does not require device names. You should go to Start>Programs>National Instruments>NI-488.2>NI-488.2 Help.
(4,030 Views)
