Delay in output signal (unwanted)
I'm new to labview.
I'm trying to make a program that will read an input, and if the input is 1 then it will output a sinusoidal wave or if it is zero it will output zero.
I am successfully reading the input, and  can output the sine wave, however when I am reading the signal on the oscilloscope, there is a 5-10 ms 'delay' once every second and if I change what the input signal is, it will only update after 1s. I have attached pictures of my program and the output.
Is there a way to output the signal continuously (without the delay)?
Is it possible to have the wave update in real time?
Thank you
(3,894 Views)
1. It is apparent that you are using the Run Continuously.  STOP THAT!!!  It is meant for debugging purposes, not for running your code.
2. Move your controls into the loop.  This way they will be continuously read.
(3,878 Views)
I am not using run continuously. That is what occurs when I click 'Run'.
As seen in the first screenshot, the controls are in the loop, I just moved them out in the second to see if that made a difference. The program will change the amplitude, but it will still have the delay.
(3,874 Views)
Hi
I think there is gap for improvement. Have you try to use the DAQmx API instead of the DAQ Assistant? By using the API there is more chance to improve the performance of your data gathering.
You will notice that using the Express VI will take more time to execute. If you have questions on how to code this, please check this other document: https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
Hope this helps.
(3,829 Views)
I am trying to use DAQ mx but I havent got it working yet.
(3,768 Views)
