Delay in rs 232 visa
While communicating with a Siemens PLC in point to point protocol RS-232 using VISA commands, I encounter to some undesired delays which restrict timeout reduction.
The same action could be taken place by Implementing the same communication algorithm on the same protocol, executed by micro controllers. Here this time-out restriction does not reveal. Does any one has an idea to resolve this problem?
Message 1 of 11
(4,403 Views)
How much is this delay? What programming language? Can you attach your code?
Message 2 of 11
(4,400 Views)
Hello Dennis,
Thanks for your attention. the occured delay is 30 msec between each VISA write command. I attached the related simple block diagram.
I am awaiting...
Message 3 of 11
(4,390 Views)
What happens when you build all outputs in one string and output this, instead of calling visa for each character?
greetings from the Netherlands
Message 4 of 11
(4,387 Views)
Hello.
I did it before. Unfortunately nothing happened!
Message 5 of 11
(4,384 Views)
no delay or no action in the plc?
Message 6 of 11
(4,382 Views)
Yes. Nothing as particular. When I recalled a command, I could see by my eyes the delays between running the command and recalling it!
Is that required to use authorize RS232 PCI cards of NI? You see, while working with NI IMAQ USB instead of PCI 1411, you encounter to a reduction in frame acquisition. It reduced to almost 15. I think this is a kind of intentional restriction to encourage users to buy expensive cards! Is'nt it?
Message 7 of 11
(4,381 Views)
Yes. Nothing as particular. When I recall a command, I can see by my eye the delay between recalling and running the command.
Do you think that it relates to the use of authorized NI PCI RS 232 cards? You see, for example, when using NI IMAQ USB instead of NI PCI 1411, you encounter to a reduction in frame rate, it reduces from 25 to 15, and it does not matter what is the CPU usage. It is deliberately indeed!
However, I guess this problem relate to the same reason! Isn't it?
Message 8 of 11
(4,380 Views)
Or maybe your USB camera is slower....
I really don't understand what does and what does not happen. Sorry for not understanding.
Message 9 of 11
(4,372 Views)
I think it is ridiculous to think that NI would reduce the VISA speed when using non-NI hardware. Are you using a USB-RS232 adapter? There is considerable latency with that type of connection. How are you measuring the delay? I would also agree that you should send the entire string at once.
Message 10 of 11
(4,356 Views)
