Demultiplexing a signal coming from Serial Port
Hey,
       I want to build a labview VI. In which i am reading a signal from serial port. I have used ADC0808 with 8051 to convert 4 ananlog signals to digital and used 8051 microcontroller to send the digital signal in the form of ASCII numbers. For example the string to serial port is
203,204,206,210
Where 203 is a signal,204 is another signal etc.
Comma has been used to separate these signals (in microcontroller programming.)
In labview VI how can I separate these 4 signals and add 4 meters to them to display these values.
(3,466 Views)
I want the first input 203 to go to first meter
the second input 204 to 2nd meter
the 3rd input 206 to 3rd meter
the 4th input 210 to 4th meter
(3,455 Views)
Please do not double post.
If you are impatient, please learn some patience. These forums are made up primarily of volunteers, and most of us, like me, have full-time jobs.
All discussions on this should take place in the thread in the LabVIEW forum.
Message Edited by smercurio_fc on 06-07-2010 04:41 PM
(3,438 Views)
