08-22-2007 10:48 AM
08-23-2007 06:01 PM
Hi Antoine.
Thanks for posting to the NI Discussion Forums.
That seems to be some strange behavior that you are experiencing. I have a few questions and suggestions so I can help you find out what is going on here.
First, I am not terribly familiar with the instrument in question and searching our website and google didn't turn up much. So, first, is the Lambda EMS II power supply SCPI compliant? In other words, are you sure that commands such as *IDN? are valid commands to be sending to the instrument? Also, is it expecting some sort of termination character signaling the end of your transmission? Secondly, can you explain the RSTL programming interface that you are talking about? Thirdly, what device are you using to communicate with the instrument? Is it one of our GPIB's? If so, which one?
Also, if you use Measurement and Automation Explorer (MAX) which is a NI software program, you should be able to detect the instrument. Are you able to see the instrument in MAX?
Let me know and I will be happy to provide you with whatever assistance I can.
Have a great day!
Brian F
08-28-2007 10:07 AM
Thank you for responding.
The EMS series is there http://www.lambda-hp.com/product_html/emspower.htm, there's only one manual for all EMS device on the site, but i have compared the shipped manual exclusive to my device and the one on the net and they agree....My device, the EMS 2 is listed as EMS 10-500,....10V 500A 5000 W.
So basicly, if you buy that kind of source, you will have a controle panel at the front but no GPIB or any port. To communicate with the source using a pc, you gotta buy a RSTL, a little improvement that connects to the rear of the actual EMS device and allows one gpib port.
As for the termination caracter, i have not seen any information about this in any manual, but i have tried all the termination options a it didnt change anything. The manuals, however, specify that the EMS(RSTL) should respond to a *IDN? query, among others. The two manuals are at the upper left corner of the site i linked, the product manual (EMS), and the RSTL programming guide.
Finally, the ni instrument detection or something like that detects it, and where it should be showing the instrument brand and model, like it does with the keitley or anything else, it shows "device cleared".
I'm using a national instrument cable, but im not at the lab right now so its hard to tell you wich one, i think it's GPIB-USB-HS. I'm also using HP GPIB splitter to communicate with the keithley at the same time, but the adress don't interfere.
thank you,
antoine
08-28-2007 10:15 AM
08-29-2007 09:45 AM
The GPIB slitter...worked fine in many applications, I dont know how to describe it with accuraccy, but it's oubvioulsy not artisanal and meant to be used that way.
Anyway, I tried with and without, and it didnt change much.
Thank you and please do not give up suggesting.
08-29-2007 09:59 AM
Have you talked to Lambda about this issue? I think there's a good chance that there is something wrong with it. Maybe there is a problem with the firware or the installation of this RTSL interface. If MAX is able to detect other instruments with no problems, that would say to me that there is nothing wrong with the GPIB controller or the NI driver. Just to be sure, can you try to detect the instrument on a system with a different GPIB controller?
08-29-2007 12:47 PM
08-29-2007
01:06 PM
- last edited on
02-03-2025
11:58 AM
by
Content Cleaner
08-29-2007 04:13 PM
05-27-2008 02:49 PM
