Deterministic communication in Windows
Hi, we purchased a PCI 485/8 card to interface with an embedded processor at 300 Hz. However the Visual C++ timers are only getting us to 60 Hz. Any ideas on how to work around this? Are we better off going with LabVIEW?
Gary Willenbring
SAIC
Message 1 of 8
(5,154 Views)
I'm not sure if I understand your question. By 300 Hz, are you sending packets of data 300 times/sec at a high baud rate, or are you sending at 300bits/sec? Are you looking to send a packet of data every 3.3ms?
Message 2 of 8
(5,154 Views)
Chris, we are looking to send an 8 bit message every 3.3 ms.
Message 3 of 8
(5,154 Views)
What type of jitter is allowed? Also, what baud rate are you using?
Message 4 of 8
(5,154 Views)
We are trying to minimize jitter as the communication is attempting to simulate a second embedded processor.
The baud rate is pretty high, I want to say 115k but not positive.
Message 5 of 8
(5,154 Views)
In general Windows is not a very deterministic OS, and thus being able to guarentee timing at the ms level can be quite difficult. If moving to labVIEW RT is not an option, then perhaps you can use something like the queryperformancecounter (which returns the value of the high-performance counter) to control your timing loops.
Note that with a 1.2GHz system running windows, we see jitter on the order of 10ms - so you could have two successful writes at 3.3ms each, followed by a 13.3ms pause.
However with LabVIEW RT, timing is much more accurate, and we have timing on the order of 100us.
Message 6 of 8
(5,154 Views)
Do you think using an external timer, such as a counter from a DAQ card, could be used to run a timing loop?
Message 7 of 8
(5,154 Views)
Can you email me: chris.rake@ni.com.
Thanks!
Message 8 of 8
(5,154 Views)
