Developing a USBTMC-device
My USBTMC-device under development recognizes a MsgID = REQUEST_DEV_DEP_MSG_IN(equivalent to LabVIEW's VISA READ), but not a MsgID = DEV_DEP_MSG_OUT(VISA WRITE). It seems like the latter MsgID is not sent at all. After a few seconds delay, the host sends the control pipe request INITIATE_CLEAR.
LabVIEW is version 7.1, NI-VISA 3.3.1
If problem description is insufficient, please let me know.
(5,085 Views)
Hai
I am too developing one TMC device. Can you help me in clearing my small doubt.
I had to send SRQ through interrupt endpoint. In TMC spec they specifies one bitpattern and the status byte to send through interrupt endpoint. But i am little bit confused with the status byte. what they actually menat of this status byte. Can you help me?
Thank you
Jufail
(5,026 Views)
With USBTMC, when you need to request service, the device shall do a ReadStatusByte (equivalant to a GPIB Serial Poll) algorithm within the device and return the SRQ AND the status byte to the host using a single interrupt-IN transfer.
Does that make sense?
(5,021 Views)
Jufail,
The Status Byte documented in USBTMC-USB488 specification is exactly the same entity of what defined in IEEE488.1 std.  For T&M devices having SR1 capabilities, there are two situations for sending out Status Byte stream through the Interrupt-IN endpoint - 1)when the device is queried by READ_STATUS_BYTE class request, and 2)when device's SRQ state has changed from 0 to 1.  The 1st one is a response for READ_STATUS_BYTE request, and the 2nd one is a packet that the device spontaneously sends out.
(4,987 Views)
Hai Makoto,
Thank you very much for your help.
(4,980 Views)
