Device (ITC503) crashes and blocks entire GPIB
Hi everyone,
I have been building a measurement program and now I have encountered a problem which I can't figure out.
I am using the USB-GPIB controller to communicate with 10 devices.
One of them, a ITC503, seemingly random chooses to freeze on a time scale from minutes to days. Nothing in the routine changes which could trigger this. The program is basically in standby and only collects temperatures.
I logged the last of these events with the NI Spy (German Version).        (my translation)
(Please take a look at the included editor file)
The last state remains until I restart the device. The only unusual thing that appears is this "J" in the device return.
Moreover, the whole GPIB is dead. I can't reach any other device and if I use the Measurement & Automation Explorer to scan for instruments there are none.
The Program prompts with the error message  "general I/O-error" "operation was canceled" and if I click on continue the next error will be "memory full" "no listener for GPIB found".
One possible source for interference could be the simultaneously mounted Oxford-ISOBUS, which connects a Power Supply (IPS120) as Master to four other devices including the one ITC 503. That's why I use a lot of Select Device Clears.
Thanks for ideas!
Message 1 of 1
(3,579 Views)
