10-16-2012 07:48 AM
Damien129 wrote:
The command for remote mode for my supply is RMT REM and i need to put \r at the end of it. Do i need to configure the string to enable codes display or leave it at normal?
Yes, show the /codes on the constant.
10-16-2012 08:13 AM
Hey thanks for the help. I just used the serial read and write and just added in sub routines using the commands to achieve what i want instead of using the power supply template. Cheers
Damien
