Digital I/O Boards for I2C Serial Communication
I'm trying to use the Digital I/O Board to genaerate and receive the Data through
I2C serial Communication Protocol.
Is there any example or code available to perform the same in LabVIEW..?
Anybody has done this before...?
Please suggest
Dinesh
Certified Labview Associate Developer(CLAD)
Don't Forget to Rate the answers.!!! You can do it in few seconds
(4,054 Views)
Have you already purchased you DIO board? If not have you looked into the NI USB-8451? It supports both SPI and I2C protocols, and ships with an easy to use LabVIEW API. Is this an option for you? If not what DIO board are you using?
Logan S.
(4,038 Views)
Logan,
Im already using the PXI-6281 card to do the same.
I was just looking for an example for the I2C protocol using digital I/O.
Dinesh
(4,028 Views)
Have you searched the Dev Zone?
here is a SPI example for the printer port, however you can get the idea
Greetings from Germany
Henrik
LV since v3.1
(4,020 Views)
