Dirver of MTX393 multimeter
1-Im looked for a driver to my MTX3293, wich is connected with a USB cable I can't find it ?
2-and if does not exist how can i get it ?
3- Can I acquire data from my multimter with VISA Only without the driver ?
Thank you for all
Message 1 of 13
(2,423 Views)
Hi
Probably yes if it supports a serial interface via usb. That should be readable in the manual.
If you have an english manual or poiint to  download page I can take a look.
greetings from the Netherlands
Message 2 of 13
(2,390 Views)
Hi
thank you for answering my question, you will find attached the document for remote progamming of the MTX3293
Message 3 of 13
(2,358 Views)
Good that the manual is clear and the commands are like SCPI.
This is a good tutorial on communicating with instruments
https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
Santhosh
Soliton Technologies
Message 4 of 13
(2,347 Views)
Hi
This instrument is perfectly programmable and readable via visa.
Look at the link Santhosh gave you in the previous message
Message 5 of 13
(2,344 Views)
Thank you for taking time to answer me, i try to send the command ":CATalog?" to read the list of extended but i cant get it
with error (tome out)
Message 6 of 13
(2,338 Views)
Hi
Please send a vi saved with all frontpanel settings. And eventually a copy of the errormessage.
I believe you have to add a linefeed after the command to get a result.
And why do you use DCI on for handshaking?
Which version of LabVIEW are you using so I can send a simple example that does a read on the instrument.
Message 7 of 13
(2,323 Views)
Hi
this is my simple program to acquire data using Vi but does not work , only error 1210
i use the 2019 version
with visa does not work with me, even i succelfully communicate with instrument on the test pannel of MAx
Message 8 of 13
(2,289 Views)
Hi
Nice vi but I miss 3 subvi's that can tell me what is wrong
Message 9 of 13
(2,275 Views)
this the LLB drivers on labVIEW from the officiel website of the Metrix
for MTX3293
can you confirm for me if the sub VI are correct , and can communicate with my instrument i will be very grateful to unlock me in this situation
thank you
Message 10 of 13
(2,268 Views)
