Dll file for LEM Instrument ref NGD6100
The NGD 6100 driver on the NI site is for Labwindows. In order to convert it for Labview, I need the NGD6100 DLL file. Could someone give me this file, or the Labview driver for the NGD6100.
Best regards
(3,488 Views)
The driver available from the Instrument Driver Network (http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/e972f321f52d8b3b862568ab005fbce1?OpenDocument) is a legacy LabWindows/CVI version. Legacy drivers are provided in source code format and not built into a DLL. You should be able to build this into a library or into a CIN available for porting into LabVIEW.
(3,488 Views)
