Does Ivi_WriteInstrData work?
I know the answer is probably yes, but I can't get it to work at all.  I'm trying to communicate to an Agilent E4437B and I need to pass through some GPIB commands that I can't find in the IVI driver.  When I use the Ivi_WriteInstrData function I get an error that tells me the given session or object reference is invalid.  I have functions before it and after it that work fine, with the same session.  For example:
 status = Ivi_ValidateSession (instr_handle);  //  Returns a 0 indicating that it's a valid session
 status = IviRFSigGen_ConfigureRF (instr_handle, 1.0e6, -22.2);  //  Works
 status = Ivi_WriteInstrData (instr_handle, "*RST");  // returns error
 status = IviRFSigGen_ConfigureRF (instr_handle, 2.0e6, -22.2);   // Works
 status = agesg_WriteInstrData(instr_handle, "*RST");  // returns error
 status = agesg_ConfigureRF (instr_handle, 1e9, -33.3);  // Works
 IviRFSigGen_reset (instr_handle);  // Works
Does anyone have any ideas?
Thanks for your help.
(3,934 Views)
You are accessing the instrument through the RFSigGen class driver.  You can't pass the class driver's session handle (ViSession) directly to Ivi_WriteInstrData() and Ivi_ReadInstrData() functions, which require a "specific" session handle.  To aqcuire the specific session handle, you must use IviRFSigGen_GetSpecificDriverCHandle() function.
(3,922 Views)
Thanks Makoto!!  Worked like a champ!
(3,912 Views)
