Does NAT9914 control lines require memory mapping to CPU?
I got NAT9914, a GPIB controller from NI. Looking at the connection diagram using CPU(80186), it seems like it requires memory mapping. If that's the case, there is only limited choice on the CPU. I have a STM32F101C4, an ARM 32-bit Cortex cpu and I was wondering if that would work with the GPIB controller. Any suggestion would be greatly appreciated.
(3,325 Views)
Hi GPIB.user,
I don't have experience working with the NAT9914 chip, but there's another thread I found that discusses using this chip with an ARM controller.
http://forums.ni.com/ni/board/message?board.id=140&message.id=32467&requireLogin=False
I guess the best way to find out if your ARM controller works is to try it out. The reference manual would be the best place to start.
Boon Chen
(3,281 Views)
