Does NI-Device support the AT-GPIB/TNT card?
I need to create software for a GPIB instrument. I have the AT-GPIB/TNT ISA card and the NI-Device software package. Windows NT is running on a Aaeon 656 single board computer plugged into a passive ISA backplane with the GPIB card. I can install and run the NI 488.2 software fine, using the card as a controller. However, I need software for the card to act as a device. I uninstalled the NI 488.2 software and installed the NI-Device software. I get a HARDWARE_NOT_FOUND error when running the GPIBDevice sample code. Is the ISA AT-GPIB/TNT card compatible with NI-Device standard? If so, what could my problem be?
(3,489 Views)
The AT-GPIB/TNT is not supported in NI-Device 1.3. According to the release Notes the following hardware is supported:
PCI-GPIB
PCI-GPIB+
PCI-8212
PMC-GPIB
PXI-GPIB
PCMCIA-GPIB
PCMCIA-GPIB+
Note: the PCMCIA-GPIB and PCMCIA-GPIB+ interfaces are not supported under Windows NT4.
DiegoF
(3,489 Views)
Brian,
I have a utility that may help you out. Please email me at gpibguru@hotmail.com and I will get in touch with you offline.
Eric
(3,489 Views)
