Does PCI-6534 work on Win7 32bit with DAC (Legacy) 7.5 and if so, NI-VISA or NI-PXI
I have a PCI-6534 DAC installed in a Windows 7 32bit machine. I've installed:
NI-DAQ (Legacy) 7.5.0
NI-VISA 5.4.1
NI-488 3.1.2
PCI-6534 shows up in Measurement & Automation Explorer. However, the 6534 is not showing up under VISA and I can't communicate through VISA. The only VISA devices that show up from Python are the serial ports. I'm told that this SHOULD work by other engineers. It that is true, what am I doing wrong? What can I check next?
I'm beginning to think VISA is not supported on the PCI-6534. If not, how do I communicate with this card from Python 2.7.6? Is there a DLL or through NI-PXI?
(4,415 Views)
Why can't you use python with the supported api - DAQmx? Who told you to use VISA?
(4,398 Views)
