Does VISA support 422 serial communication?
I am looking into serial communication using an RS422 adapter. Does VISA directly support 422 communication or would an external driver be required?
(3,487 Views)
RS-422 is a physical layer whereas VISA deals with the software communication / UART layer. As long as the RS-422 adapter appears as a standard com port, VISA should have no problems communicating with the port. However, some additional features (such as transceiver control) are only supported for NI's 485 (422) serial products. If you do not have a RS-422 card, you can either purchase a RS-232 to RS-485 external adapter, or go with a RS-485/422 plug-in or ethernet solution which National Instruments offers with isolated and non-isolated options.
(3,487 Views)
