12-19-2011 11:09 AM
I want to plot in a Labview program the measurements acquired from a HH309A Omega thermometer. If someone has a VI for this, please let me know.
Best regards.
12-20-2011 11:48 AM
Do you want to acquire the measurements continuously? ¿Or after any given time, retrieve the available data for processing?
Regards!
Anuar Rojas
12-20-2011 12:35 PM
Dear Anuar Rojas, thanks for your response.
The priority is to acquire measurements continuously for comparison with references, which will be used for temperature control.
Regards.
Marco Felix
12-20-2011
01:16 PM
- last edited on
09-26-2025
10:00 PM
by
Content Cleaner
You can use the NI LabVIEW Instrument Drivers: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3XpCAI&l=en-US
Also, there is a Universal Library for LabVIEW available for some OMEGA devices: http://www.omega.com/manuals/manualpdf/MLabviewRef.pdf
I honestly recommend that you ckeck put the folowwing websites:
http://zone.ni.com/devzone/cda/tut/p/id/12118
You can use the NI VISA Instrument Drivers to communicate with the HH309A and extract the data as it is being acquired. As a matter of fact, you can write the commands through LabVIEW and start acquiring inside the application itself.
Hope this helps!
Anuar Rojas
