Does anyone have an example for controlling an agilent 33220a over TCP/IP connection?
I would eventualy like to send waveforms to 24 of these Abs and receive scope data back  from 24 scopes.  This is to be used in a electonics lab for testing students in the use of instuments.
(3,745 Views)
Unless it's some sort of secret, do you think you might provide the progamming language you are using?Smiley Wink
You can go to the Instrument Driver Network and search for the 33220A. There happen to be drivers available that you can use in a variety of programming environments. Source code is included for all. On the same page are links that explain what a driver is and how to use one.
(3,743 Views)
