Does anyone have experience with activate SICL errors using an agilent G1680-63715 pci card?
If the computer is does anything that max out the cpu I will end up with a bunch of activate sicl errors and our chemstation software will crash. If someone has experienced this type of error, have you tried using a NI488.2 pci card with onboard bus mastering DMA and did it solve the problem?
(4,589 Views)
Hi nmath6,
It seems like both your hardware and your software are from third party providers - this question may be more suited for the third party forums.
If you'd like to know more about the specifications of an NI PCI card, I'd be happy to help, but I'll need more information about you application. What is causing the CPU to max out? What is your desired behavior? Do you want to run the CPU at max without receiving errors? Or is the CPU maxing out the problem?
Derek B. (esoDerek)
Product Marketing Engineer
(4,562 Views)
