Driver_IRQ_Not_LESS_OR_Equal message along with Random Computer Rebooting.
I am running Labview 5.1 on Dell 800Mhz Pent3, with 256 mb of PC-133 ram. During an experiment the pc reboots randomly, we tried everything from changeing the ram locations to changeing rams itself. We also changed PCI locations since our PCI-GBIP is shareing it's IRQ with our AGP video card and the USB controller. We tried to manually change the IRQ setting but to no avail, manual control is disabled.
Suddenly first time we got a BSOD which clued as in onto the problem. the BSOD said
Driver_IRQ_Not_LESS_OR_Equal...address BFE0E58A base at BFE0A000, datestamp 37939fe5-gpibpci.sys
Thus by changeing the GPIB driver fix anything? or is this a compeletly different beast (rebooting and BSOD be
ing different).
Thank You for any and all help.
(3,571 Views)
The lastest NI-488.2 driver is 2.0 (1.7 in some OSes). What driver version are you using?. Also, What OS are you using?.
The most important information we can use is a way to reproduce the problem. If you have a specific sequence of events or a piece of code that generates the blue screen let us know. Describe what actions you take before the BSOD occurs.
DiegoF.
National Instruments.
(3,571 Views)
