Driver Problem for NI VISA for USB Instrument
Hello,.
I am using Texas Instruments MSP430 Flash emulation tool(USB device) for Flow Sensor Project, I want to display the temparature readings in Labview in my PC, I want to enable the device as NI VISA instrument.
I have tried the USB instrument tutorial to create driver using Device development wizard (DDW). I have installed the driver using .PNF file created. The system culdnt detect the device under VISA devices  and display it in measurement and automation hardware devices!
Is thr any way i can resolve this issue?  or is thr any othr way so tht i can display readings frm USB device.?
(4,098 Views)
Hello aarief,
Unfortunately there is no standard support for the driver development kit. Only OEMs are supported with the DDK.
The MSP430 is the programming (JTAG)-Interface to your TI-MCU. There is no "regular" instrument driver available, because
the most common use-case is to program a target with it through the respective C-Compiler for the target.
You could built a Toolchain to your target with LabVIEW Embedded, but this would just be an extension of the original TI-toolchain
enabling you to program and debug the target with LabVIEW.
There is another way to communicate with the MSP430, the Bootstrap Loader, a character-oriented serial protocol which can be enabled on the chip.
This thread from some NI- users describes it a little bit: http://forums.ni.com/ni/board/message?board.id=170&thread.id=204219&view=by_date_ascending&page=1
But this is not supported by NI.
best regards
Marco Brauner NIG
(4,067 Views)
Yes,..Labview Embedded is only for 32 bit MCUs,. but MSP430F2274 is 16bit MCU..
but is there any method so that i can display readings from my USB MCU Emulator module directly in Labview in my PC..
like if i save the reading in form of matrix or txt file from USB module and use that matrix in analysing the values and displaying them??
(4,053 Views)
Hello aarief,
LabVIEW is not directly involved as there is no driver for direct communication with the programming interface (PI),
so you have the following choices:
- program directly with the PI´s driver dll (I dont´know if this is possible and documented...)
- active-x programming (automating) the IDE in order to exchange data with LabVIEW
- programming of the UART Serial Interface of the MCU (which, in my opinion, would be the easiest and most convenient choice)
Reading the values from a file is ok, but how do you write the file in the first place? Once you have a way to access your values, you can transfer them to LabVIEW and no
File I/O would be needed at all...
regards
Marco Brauner NIG
(4,024 Views)
