Driver du NI PXI-4065
Bonjour,
j'ai besoin du driver du NI PXI-4065, je suis entrée sur la page du driver mais je ne l'ai pas trouvée, pourriez vous m'aider s'il vous plaît?
Merci d'avance.
(5,548 Views)
Hi Yasmine,
here is the link to the latest NI-DMM:
NI-DMM 14.0
http://www.ni.com/download/ni-dmm-14.0/4820/en/
(5,505 Views)
Hi Gregor,
Thank you for your reply, I will try it, I hope it will work this time, because I tried to download an ancient version of this but once downloaded it didn't want to work.
Have a nice day.
(5,502 Views)
I've just downloaded the folder, but when I executed it, it tells that the files are corrupted and it can not be opened as shown in the file below.
What should I do? Is it a problem from the driver itself or from the license?
Thank you in advance.
(5,486 Views)
The download itself is corrupt. Delete it and try again.
(5,482 Views)
