Driver for Agilent E3647A Dual Output DC Power Supply
I need to control an Agilent E3647A Dual Channel power supply through a GPIB interface using LabVIEW. I tried the drivers for the E3640A, E3642A, and E3644A but they do not provide for dual outputs. I need to set the P/S in constant current mode, set the current level, and enable and disable the outputs. Can anyone help?
(4,167 Views)
You could find a LabVIEW/CVI driver for this instrument at http://www.ni.com/devzone/idnet/default.htm or the instrument manufacturers website. If it's not listed there, it leaves you with one of a couple options. First, I would like you to submit a request for this driver at: http://zone.ni.com/idnet97.nsf/instrumentdriverrequest/ and with the instrument manufacturer. Many a times driver for instrument model xxxA works with model xxxB minus some features.
We develop drivers based on demand and popularity so the more requests we have for it, the greater the possibility that we will develop one.
If you would like to try developing your own instrument driver (or modify the existing one), we have documentation, model instrument drivers, and driver templates to help a
t :
http://www.ni.com/devzone/idnet/development.htm
We also have a syndicate of third party vendors that specialize in National Instruments' products and services. Some of the vendors specialize in driver development. I would suggest contacting one of the Alliance members at:
http://www.ni.com/alliance
An instrument driver is a collection of functions that implement the commands necessary to perform the instrument�s operations. In short, someone read the instrument user manual and implemented some of the functionality in a program for the end user. Instrument drivers are not necessary to use your instrument. They are merely time savers to help you develop your project so you do not need to study the manual before writing a program. With all of this work already done for you in the driver, instrument drivers can significantly reduce development time.
There are example VI's in LV on Instrument Connectivity. If you go to the Help menu >> Examples.. >> I/O, you will see a
couple and Examples.. >> Fundamentals for File and String manipulation. I would suggest tweaking them to suit your application. Also the specific command that your instrument responds to can be found from it's manual.
(4,167 Views)
