Driver for NI USB-9161 and Software
I'm new to the forum and hope I'm in the right place. If not please move to the right forum.
My problem is that I am trying to take temperature measurements, but I only have an old NI USB-9161 with an NI cRIO-9211 connected to it. Are there still Windows 10 drivers for it and what software do I need to take measurements with the device.
Thanks for any help.
(994 Views)
Accepted by topic author TS_GH
Hello!
You will need to install the DAQmx Base 2.2 driver. Programming is only supported with LabVIEW versions 7.0 to 8.2 or C. If you want to program another way, you will need to use a different carrier module or a cDAQ chassis. Then you can use the DAQmx driver which supports newer LabVIEW versions and other programming languages.
Links that might be helpful:
DAQmx BASE 2.2
USB-9211, USB-9215, or USB-9161 Unavailable in MAX
(951 Views)
