Driver modification problem
Hello All,
So I came up with something I understand but still am not able to control the instrument by inputting a wavelength.  Can some one please advise, I have attached the file.
Thanks for your time
-Rafael
Message 11 of 16
(1,941 Views)
I have exactly the same problem with the same error messages. I've tried different baud rates (9600 and 11520) as well as different comm port (COM3 and COM8). Interestingly those settings worked fine when I run the windows application from ThorLabs. http://www.thorlabs.com/software_pages/PM100.cfm
I emailed ThorLabs earlier this evening. Since they're in the east coast I probably wouldn't hear till tomorrow.
Vincent Su
Message 12 of 16
(1,932 Views)
BTW, I have LabView 8.5, VISA 4.2 and Windows Vista Business 32-bit.
The DLL is located in the same directory as the LabView LLB.
Vincent Su
Message 13 of 16
(1,931 Views)
Hello Vicent,
On the website for that product, they asked for the VISA 3.0 to be used.
Can you try installing that on your system and testing the application?
Christian A
Message 14 of 16
(1,919 Views)
Chris,
I have multiple devices connected and I don't want to downgrade to VISA 3.0 at the risk of breaking any other device that currently works.
I just got a sample VI to read power from ThorLabs App Eng.
Vincent
Message 15 of 16
(1,909 Views)
Hello Vincent,
I understand your situation.
Did that sample work for you?
Can you post the Spy logs for your application
Christian A
Message 16 of 16
(1,888 Views)
