Drivers for Delta Design 9023 Environmental Chamber and 9015 controller
I have difficulty in making dd9015ctrl.vi for delta design 9015 controller to work. I am suspecting that my Delta Design 9015 controller might be an older version. Is there a solution to this problem.
(4,391 Views)
Which controller do you have? It can also be related to the VISA version you have. Please see the link below which contains the  Delta Design dd9015 instrument Drivers with the VISA version required
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7FCE2029819E5463E04400144F1EF8...
(4,363 Views)
Thanks for your interest. The chamber is 9023 but the controller is 9015 from Delta Design. Right now I am out of town. What you suggested is on top of my to do list.
(4,348 Views)
It would depend of the LabVIEW version you have, be sure to have NI-VISA 4.2 as well
(4,332 Views)
Labview version that I am using is 2012. The chipset from E-Prom has been updated I guess in 2007. The latest Firmware is DT7200CG. I guess I will try to have one.
(4,309 Views)
