Dynamometer control unit
Good Morning
I have aproblem with Dynamometer Control Unit(DCU),
A program works with windows 2000, but the same program is not working with XP(for example,with 2000 if i write some value to the device it writes immediatley ,but with XP there is a delay),this is time critical application.
Communication between PC and DCU is through GPIB.
Please give me some suggestions
(3,395 Views)
Good Morning Veru,
I hope you are doing fine. I want to ask what form factor of GPIB are you using and what are you trying to do in your application ?
Fawad Nisar
National Instruments UK & Ireland
(3,352 Views)
