E5061B
Hi
I have to use the NA E5061B to measure the impedance of a system , can someone explain to me the procedure for calibration and measure??? i followed the manuel steps but it doesnt work.
(4,546 Views)
Hi tytoo,
Do you use this drivers to communicate with your E5061B:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=17778
Are you able to communicate with this instrument with basic command like *IDN? ?
Can you share a simple version of your code with which you are dealing with ?
Is there any error code you encountered ?
As you see, we will need more information to help you.
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(4,526 Views)
Hi Valentin
For now i didnot use any code i found it like that and i did the calibration and the measurements manually, i guess someone who use it before me was him who did the configuration.
i have some questions like how to choose the calibration depending of the DUT ? and how to do to store the pictures on a USB key?
Cordially,
(4,521 Views)
Hi tytoo,
If you have question related to commands to send to the E5061B, I will recommand you to ask Keysigth due to the fact this is a Keysigth HW.
Are you able to provide us the link where you find the programm you are using ?
Valentin
(4,511 Views)
