EDVR(0xe0140035)
Hi, I have a problem on GPIB communication. The GPIB controller is NAT9914BPD and the transceivers are DS75160A and DS75161A. I set GPIB at TALK/LISTENER mode in instrument. When I try to find it with the interactive control utility, It cannot find GPIB.
:ibfind  gpib0
gpib0:ibsic
  cmpl cic atn
gpib0: ibdev
An error report: EDVR(oxeo140035).
Then I try to set 488 again:
:set 488.2
499.2 (0): sendifc
  cmpl cic atn
488.2 (0): findlstn
enter address list: 1,2,3,4,5,6,7,8
enter limit number: 1
count: 0
8130(err cmpl cic atn)
What may be the possible problems? I am a new one on GPIB interface, Your help is appreciated very much!
(3,674 Views)
Could you clarify your set up?  Are you working with a GPIB interface (ie PCI-GPIB) and connecting to a machine where you are using the NAT9914 chip?  What software are you using on either end?  Just NI-488.2?  What version?  What operating system are you working in?  Please let me know.
Logan S.
(3,654 Views)
