ENET-232/2 work with VISTA or Windows 7?
We are looking at using the LAN to RS-232 device on a new system with LabView and Vista.  The data sheet (which may be old) only lists XP.  Will it work?
Steve
(3,677 Views)
The ENET-232/2 device is supported under the latest NI-Serial driver. The Readme file states that it supports your hardware on Windows operating systems including Windows Vista.
It will work.
Peter Flores
(3,657 Views)
There is a note in the readme which indicates that the ENET serial devices do not have native driver support on 64-bit versions of Windows. You can still use them through NI-VISA (meaning a LabVIEW app should be fine), but they will not actually show up as a COM port on the system. They are supported as COM ports on 32-bit versions of Windows Vista and Windows 7.
-Jason S.
(3,638 Views)
