ENET-232 SDS for Windows NT does not work
The ENET-232 has been installed and configured. Now, when we run a VB application against it we get just one portion of data from each serial device. And that is all. No more data can be received from the comport buffers. They are empty. Why?
(3,151 Views)
I'm not sure what is going on but there are a couple of things to try.
1) Can you communicate directly with hyperterm?
2) The Enet connection introduces a delay which needs to be accounted for. You may need to increase your read timeout.
(3,151 Views)
