ENET 9163 stops communicating
Please check earlier messages in this thread for "ping" and "telnet" tests to confirm you can reach the device (and hence it's not blocked by IT).
Then you should confirm communication with MAX.  See earlier messages about timeouts in max (registry).
Finally, I found it useful to call the nidaqmx reset device function after my code initially connects to ENET.
Message 21 of 22
(1,086 Views)
thanks maherhome for the response.
Actually in MAX I can use the Test Panels and it works fine, the ping is OK and i have't check the telnet connection.
I increased the timeout en the registry, right now it's on 40secs.
Message 22 of 22
(1,085 Views)
