ERROR -107 400 1665
Hello
I have already solved the missing last value.
The subvi also got faster and more readable.
I tried to find the NOP? command but did not find it. It suggests number of operations but maybe it is not needed.
I did not solve the output of the for loop, Now you only have the last measured registers.
greetings from the Netherlands
Message 11 of 15
(1,095 Views)
Hello Albert,
Thank you very much for your efforts and for providing me the code.
I think I found a way to store whole data in a 1D array without using a For loop. A command called "Delimited string to 1D string array" reads the whole string and saves the data to an array without the use of a For loop. However, I need to test it with the instrument and it is only possible after the weekend.
 I will let you know if it works.
Please have a look at this command in the screenshot.
Best Regards,
Harpreet
Message 12 of 15
(1,090 Views)
Screenshot 2024-01-13 185037.pngHello
If you look at the lowest level of Read Register data.vi you will see the same approach.
Now with LabVIEW primitives.
Message 13 of 15
(1,083 Views)
Hello Albert,
I tried your suggestion and the program is working fine now without any error.
I am also able to retrieve data without the use of a For loop.
Thank you very much for your help otherwise it won't be possible for me to solve this issue in this short time.
Best Regards,
Harpreet
Message 14 of 15
(1,050 Views)
Congratulations.
Glad I could help a bit.
Message 15 of 15
(1,042 Views)
