ERROR - 1073807178 Incompatible bcdUSB value (expected 0x110 or greater)
Hi Guys
I am trying to control R&S®NRP-Z23 with PyVISA but the device cannot be detected by PyVISA. However when I check it in NI-MAX it shows the device is there but it  is shown as Miscellaneous VISA Resources. And then I found it in VISA driver wizard. When I was trying to install the driver the following msg popped out:
I have checked a similiar message in this forum and tried everything I can but it didn't work. I am a new guy in controlling equipment with python and I really need you guys to help me out.
Thanks!!
(4,790 Views)
@Peixiang wrote:
Hi Guys
Thanks!!
Since you are using non-NI products, what makes you expect support here on a NI forum?
Contact the people who wrote PyVISA.
(4,772 Views)
