ETHERNET PROBLEM
Hello and Good day
I want to connect my pc (windows 😎 to the oscilloscope TDS3012C and read all the reading at the labview
I already tried by using
1.NI MAX. and i cannot detect any connection from the scope (as attached)
2. By changing Ip address from the scope. when i first time operate this scope. it doesnt give any ip address. so i assigned any ip number as attached
I followed  step by step from this link - http://www.tek.com/support/faqs/how-do-i-connect-my-oscilloscope-ethernet-connection-ni-visa but in wins 8 there's is IPV4 and IPV6. i already change the ip adresses at IPV4. and open web address http://'ip address'/ but nothing came out.
(5,343 Views)
You were already told what you needed to learn with your other thread. No need to rehash the same topic.
http://forums.ni.com/t5/LabVIEW/GPIB-PROBLEM/td-p/3003491/page/2
(5,320 Views)
Sorry nyc
I though it was different title which is in different room. I will delete this post as soon as possible.
thanks
(5,317 Views)
